Previous Topic: ImportingNext Topic: Perform an Import
How to Set Import Options
CA Process Automation provides you with some flexibility in how to import objects.
Import, Do not import, and Import and replace are the options.
Set Imported Version as Current, Make Imported Custom OPerators Available, Publish Custom Operator Group Configuration are the options. You can select none, one, some, or all.
If your import includes custom operator, select Make Imported Custom Operators Available.
If the custom operators are new and they belong to a new custom group, take the action appropriate to your environment.
Consider the import content when you configure Set Imported Version as Current and select how to handle duplicate names.
