Previous Topic: Save Changes to a Checked-Out ObjectNext Topic: Check In an Object
Discard Changes to a Checked-Out Object
After you check out, modify, and save an object, you may decide that you do not want to continue working with that specific version. Even if you saved the working version numerous times, you can perform an "Undo Checkout" to discard the saved working version.
  1. Click the Library tab.
  2. Right-click the object in the main window and select Check In/Out.
  3. Select Undo Check Out.
    The application ignores the changes that you saved to the working version and checks in the object.
  4. To continue working with the object, check it out again.
