Previous Topic: View Release Version InformationNext Topic: Baseline the Release Version of the Objects
Set the Release Version of Objects to Export
The Versions tab displays information about the release version(s) that are set for the selected object. You can set the release version when you are ready to deploy an object to a production environment. An object's release version typically identifies its specific version for deployment. Through the Release Version field, for example, you can set the release version attribute for a process and each associated object.
When you are ready to deploy an object to a production environment:
Note: See What is the Difference Between Exporting an Object, a Folder, a Content Package, and a Package for more information.
In each case, the exported file contains the value of the release version attribute of each object being exported.
You can set the release version in the following ways:
From the Library
  1. Click the Library tab.
  2. Select a folder from the left pane and then a single object from the list in the right pane.
  3. Right-click the object and then select Properties.
  4. From the Properties pane, click the Versions tab.
    Note: See the tooltips or the User Interface Reference for field descriptions and examples.
  5. Right-click the applicable version and then select Set Release Version.
  6. Enter an appropriate value in the Release Version field.
From the Versions Tab in the Object Editor
  2. Double-click an object.
    The current version of the object opens in the object editor.
  3. Click the Versions tab.
    Note: The process editor does not contain a Versions tab.
  4. Right-click the version of the object to deploy and select Set Release Version.
    The Release Version field opens.
  5. Enter a release version for the object, and then press Enter.
While Checking in an Object
See Check In an Object.
