Previous Topic: Designer TabNext Topic: Configuration Tab
Process Designer
When you open a process from the Library Browser, the Designer tab appears. Each open process appears in its own tab.
View Menu
Hides the Operators, Dataset, Properties, and Navigation palettes. You can dock the properties and datasets palettes to the right or bottom.
Operators Palette
Drag and drop operators from this palette to your process layout. You can enter search criteria (for example, "Get") to filter out nonmatching operators.
Dataset Palette
Use this palette to view, edit, and add variables in process or operator datasets.
Properties Palette
Use this palette and its additional buttons and windows to manage the properties of the currently selected operator.
Navigation Palette
Use this palette to navigate to specific regions inside large processes with multiple lanes. As a convenience, you can pan in any direction within this palette instead of scrolling the main designer layout up or down.
Process Designer
The actual process design appears in this work area, canvas, or layout. The Process Designer includes the background grid and one or more lanes.
Handler Editors
In addition to the Main Editor, the designer also includes two other tabs along the bottom for editing exception and lane change handlers.
See the Content Designer Guide for more information.
