The Agents tab displays the following read-only properties when you select an agent touchpoint on the Domain hierarchy:
Identifies each agent that is associated with the selected touchpoint.
Displays whether the agent touchpoint is active or inactive. Operators can run on an agent only when the agent is active.
Indicates the priority that is set for the corresponding agent host.
Identifies the FQDN of each agent host that is associated with the selected touchpoint.
Copyright © 2014 CA.
