The following fields appear on the Properties tab for the selected Orchestrator touchpoint. All fields are read-only. The read-only fields reflect the values for the associated Orchestrator.
Specifies whether the selected Orchestrator touchpoint is associated with the Domain Orchestrator. Default value is Domain name.
Specifies the name of the host computer on which the associated Orchestrator is installed.
Specifies the name of the corresponding physical Orchestrator host, which is displayed under the Orchestrators node.
Specifies the name displayed in the Configuration Browser for the selected Orchestrator touchpoint. The name can be the default name or the value specified by selecting Rename for the selected Orchestrator touchpoint.
For example, you name the original Orchestrator in the Domain hierarchy to Domain Orchestrator Touchpoint to differentiate it from the Domain Orchestrator (physical) displayed under the Orchestrators node.
Specifies the status of the Orchestrator. Statuses include active, inactive, locked (and the name of the user who locked it), and quarantine.
Specifies the setting configured for the associated Orchestrator.
Specifies whether to inherit the value for Secure configured in Environment properties, or set the value to true or false at the Orchestrator level.
Values: This value can be one of the following:
Default: Inherit from Environment
Specifies the search scope for an operator target when the Target field entry is an IP address or a host name (FQDN). The operator execution on the target can proceed only when the target is known to CA Process Automation. Select Disabled to allow the broadest search. Select Enabled here and Disabled for the next field for the most restricted search.
Note: A DNS lookup of a specified hostname finds associated IP addresses; a DNS lookup of the IP address finds associated hostnames.
Values: The drop-down list has the following values:
Host group reference to a remote host (exact)
Host group reference to a remote host (exact or DNS lookup result)
Note: This field is configured only when the "Match target in Host Groups only" is set to Enabled.
Specifies whether to limit the search through Host Group references to the entry type. For example: When the Target field entry type is an FQDN, search only host name patterns. When the Target field entry type is an IP address, search only subnets. When a DNS lookup is included, the search can also accept a host group reference to the other type, as resolved by a DNS lookup.
Values: This drop-down list has the following values:
Default: Inherit from Environment.
Copyright © 2014 CA.
