Previous Topic: Properties: DomainNext Topic: Properties: Host Group
Properties: Environment
The details on the Configuration Properties tab depend on the selected node in the Configuration Browser. The following descriptions are for fields that appear on the Properties tab when an environment is selected.
Name
Indicates the name of the environment. This field is a read-only field.
Status
Indicates the status of the selected environment as Active or Locked by <username>.
Operators Autorecovery
Specifies whether to automate recovery. Recovery applies to certain operators that fail with a SYSTEM_ERROR. Operators subject to recovery must be part of processes that are in a BLOCKED, RUNNING, or WAITING state. Select True to begin recovery when the inactive Orchestrator or agent becomes active. Recovery resets operators that were in SYSTEM_ERROR and resumes their processes. The reset operators in a resumed process begin running on their targets. Operator targets can be Orchestrators, touchpoints, hosts that are connected to proxy touchpoints, or hosts in a host group.
Values: This value can be one of the following:
Default: Selected
Touchpoint Security
Specifies whether to inherit the value configured in Domain properties or to set the value at the environment level.
Default: Inherit from Domain.
Match target in Host Groups only?
Specifies the search scope for an operator target when the Target field entry is an IP address or a host name (FQDN). The operator execution on the target can proceed only when the target is known to CA Process Automation. Select Disabled to allow the broadest search. Select Enabled here and Disabled for the next field for the most restricted search.
Note: A DNS lookup of a specified hostname finds associated IP addresses; a DNS lookup of the IP address finds associated hostnames.
Values: The drop-down list has the following values:
Lookup DNS when matching target in Host Groups?
Note: This field is enabled when the "Match target in Host Groups only" is set to Enabled.
Specifies whether to limit the search through Host Group references to the entry type. For example: When the Target field entry type is an FQDN, search only host name patterns. When the Target field entry type is an IP address, search only subnets. When a DNS lookup is included, the search can also accept a host group reference to the other type, as resolved by a DNS lookup.
Values: This drop-down list has the following values:
