Previous Topic: LinksNext Topic: Catalyst
Link Properties
Link properties display when you right-click a link in a process, then select Link Properties.
Weight
Specifies the thickness of lines between operators.
Color
Opens the Choose Link Color dialog, in which you can change the color of links in the process.
Shapes
Specifies the line shape for links between operators:
Straight
Creates straight links between operators.
Orthogonal
Creates right-angled links between operators.
Dashed
Click this check box to create a dashed (dotted) link.
