Previous Topic: CA Process Automation System FunctionsNext Topic: absPath
Return Types
System functions returns values of several types. In a few cases, the return type depends on the input parameters or on whether the function is returning a “null”. In most cases, system functions return Java types rather than pure Javascript values. For instance, system functions that are described as returning a String are actually returning a Java.lang.String. Typically, you can ignore the difference between Java.lang.String and String. In some cases, this difference impacts behavior when executing and expression or script. In the case of typeof x, where x is a variable holding the returned value from a system function, the return type is “object”, rather than “string”.
For each system function return type, the following table describes the effect on the following variables:
System Function Return Type
Javascript Variable Type after Assignment
Dataset Variable Type Created
boolean
boolean
Boolean
C2OString
object
String
C2OValue
object
ValueMap
C2OValueArray
object
ValueMap
C2OValueMap
object
ValueMap
Date
object
Date
int
number
Integer
String
object
String
String []
object
String []
void
undefined/a
n/a
