Catalyst › Generic USM Operators › SubscribeToChanges Operator › Example
Example
The Catalyst operators can be used directly in processes to build generic content. You can also use the operators as base operators of custom operators for product-specific content.
This example describes how to create Service Desk Incidents from SCOM Alerts.
To build a simple solution
- Add the SubscribeToChanges operator to a process.
- Select the SCOM Connector from the MdrProduct/MdrProdInstance lists and Alert from the entitytype list.
- Add the IncidentUpdate operator to the process. Select the Create check box and the Service Desk Connector from the list.
- Set the values of the Incident properties using the properties of the SCOM Alert object as variable expressions.
The content is now available for use.
Copyright © 2014 CA.
