Previous Topic: Execute OperatorNext Topic: Operation-Specific Parameters
Input Parameters
CatalystBrokerURL
Defines the UCF Broker URL of your Catalyst server. This value defaults to the UCF Broker URL in the Catalyst configuration.
Specify the Broker URL of the Catalyst Broker Service as:
"http://hostname:7000/ucf/BrokerService"
When using secure Catalyst communications, specify the secure broker URL as:
"https://hostname:7443/ucf/BrokerService"
MdrProduct
Defines the unique identifier of the connecting product.
CA Process Automation is identified as:
"CA:00074 (CA Process Automation)"
MdrProdInstance
Defines the unique identifier of the instance of the connecting product as registered in the UCF Broker. CA Process Automation queries the Catalyst Broker for the list of available connectors and populates this field so you can select your connector from the drop-down list.
"CA:00074:01"
Operation Category
Specifies the loaded connector descriptors for the Catalyst operators. Select a descriptor from the drop-down list.
Operation
Specifies the connector descriptor operations after you select an Operation Category. Select a connector descriptor from the drop-down list.
ParameterExpression
Defines a value map that matches the expected parameter structure.
Use this operator when the Execute operator is used as a base operator of a custom operator and the pre-execution code creates the value dynamically. You can use the dataset of the Execute base operator as a reference to construct the value.
ParameterNamespaceExpression
Defines the namespaces that are used in the parameter expression.
Parameters
After you select an Operation, click Parameters to specify the input parameters for the query. These fields vary according to the selected operation. Do not enter data for them if you have already entered data in the Parameter Expression and Parameter Namespace Expression fields.
Parameters for each operation can be found here.
