Previous Topic: Call Results ParametersNext Topic: MIME Attachments
Operation Results
Depending on the selection of check boxes in the Call Results parameters, the operation results holds the output of the SOAP Call Results.
Soap Response Body
Stores the complete SOAP response body.
Soap Response Header Data
Stores the response header.
SoapResponseHeader
Contains the stripped data of the SOAP header response.
Soap Response Data
Contains the stripped data of the SOAP call results.
AsyncSoapIntermediateResponse
Contains the complete response along with the headers received from the SOAP call.
Example (using the CheckServerStatus method):
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/">
<SOAP-ENV:Header/>
<SOAP-ENV:Body>
<checkServerStatusResponse xmlns="http://www.ca.com/itpam">
<serverStatus>Server status ok.</serverStatus>
</checkServerStatusResponse>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
AsyncSoapInterimResponseBody
Contains the body of the SOAP call response.
AsyncSoapInterimResponseHeader
Contains the header of the SOAP call response.
<SOAP-ENV:Header xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"/>
