Previous Topic: Output ParametersNext Topic: Dynamic Parameters
SOAP Call Data
serviceURL
Returns the service URL the SOAP call uses.
methodName
Returns the method name to call.
userName
Returns the user name for basic HTTP authentication.
password
Returns the password for basic HTTP authentication.
httpAuth
Displays true or false, depending on your Use HTTP Basic Authentication? selection.
soapVersion
Returns the SOAP version that the product uses to make SOAP calls, either SOAP 1.1 or SOAP 1.2.
inputSource
Returns one of the following values for the SOAP call input source:
inlineText
Returns the inline text data that is used for the SOAP call. This variable only populates when you select Inline Text as the input source.
Example:
<checkServerStatus xmlns="http://www.ca.com/itpam">
CA AuthMinder
<token>token__</token>
<user>user__</user>
<password>password__</password>
</auth>
</checkServerStatus>
FileName
Returns the inline text data that is used for the SOAP call. This variable is only populated when you select Preformatted SOAP File as the input source.
Expression Value
Returns the inline text data that is used for the SOAP call. This variable is only populated when you select Expression as the input source.
SavedCallFileName
Returns the file name from the Saved Call File field. This file contains the actual SOAP envelope that the product uses to make a SOAP call.
Example:
<?xml version="1.0" encoding="UTF-8"?><SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><SOAP-ENV:Header/><SOAP-ENV:Body><checkServerStatus xmlns="http://www.ca.com/itpam">
CA AuthMinder<token>token__</token><user>user__</user><password>password__</password></auth></checkServerStatus></SOAP-ENV:Body></SOAP-ENV:Envelope>
