Previous Topic: Mapping for Object Properties TabsNext Topic: Object Properties: Archival Policy Tab (Process, Start Request Form, Schedule)
Calendar Object:: Advanced Tab
Union icon Union
Indicates that one or more of the linked conditions must be satisfied for the combined condition to be satisfied.
Place one or more branches or basic conditions under this icon.
Intersection icon. Intersection
Indicates that the linked conditions must all be satisfied for the combined condition to be satisfied.
Exclusion icon Exclusion
Indicates a basic condition or a branch to be excluded from a rule.
All dates are excluded that are not otherwise selected. It is therefore only useful to exclude days when they are selected by another part of the rule. For example, no purpose is served by excluding Tuesdays unless they are defined as valid days by other conditions and operators in a rule. So if a condition specifies the work week (Monday through Friday) as valid days, you could use the Exclusion operator to exclude Tuesdays from this set.
Expand the Exclusion operator to show the Included and Excluded branches.
Click a branch and then add a condition or operator to define included or excluded dates.This operator has two sets of branched arguments:
Included: One or more basic conditions or branches that represent dates to be included in the rule.
Excluded: One or more basic conditions or branches representing dates to be excluded from the dates defined by the Included set.
Like icon Like
Use the Like operator to use an existing set of dates defined by another calendar object in your rule. This operator has the following parameters:
Calendar Name: The name of the referenced calendar.
Delta: Shifts the valid dates defined by the referenced Calendar by the specified number of days. Enter a negative number to move the dates earlier, or a positive number to move the dates later.
Open Days: When checked, indicates that the delta or shift only applies to open days.
For example, a new calendar rule could reference another calendar specifying backup days with a delta of 1. The resulting condition in the new calendar rule specifies the day immediately following backup days.
Dates List icon Dates List
Specifies individual dates (with years) that can be added, deleted, or reordered.
Date Interval icon Date Interval
Specifies a regular daily, weekly, or monthly interval in a range of dates from beginning to end.
For example, every week from March 1, 2015 to July 1, 2016.
Date Without Year List icon Date Without Year List
Specifies a list of explicit anniversary dates (without years) that can be added, deleted, or reordered.
This condition is commonly used to specify holidays that fall on the same day every year. Examples include January 1st and December 25th.
Date Without Year Interval icon Date Without Year Interval
Specifies an anniversary interval of dates without a year.
For example, from March 21st to June 20th (for Spring).
Year Interval icon Year Interval
Specifies an interval of years.
You can specify leap years by starting an interval on a leap year and specifying a step of 4 (such as 2000 to 2024 with a step of 4).
Month Interval icon Month Interval
Specifies one or more months in the year.
The first semester is specified with a range from 1 to 6 with a step of 1. The second semester is specified with a range from 7 to 12 with a step of 1.
Week of the Month Interval icon Week of the Month Interval
Specifies one or more weeks in the month.
CA Process Automation implements ISO standards for partial weeks. A week which intersects with a given month is considered to be part of the month if the Thursday of that week falls in the month.
For example, if June 1st is a Friday, the First week of the month starts on June 4th. If June 1st is a Wednesday, the first week of the month starts on May 30th.
It is possible to have the “first Monday of the month” not be “Monday of the first week of the month.” To define the former, it is simpler to combine “Day of the month” and “Day of the Week” conditions.
Week of the Year Interval icon Week of the Year Interval
Specifies one or more weeks in the year.
CA Process Automation implement ISO standards for partial weeks. A week which intersects with a given year is considered to be part of the year if the Thursday of that week falls in the year.
For example, if January 1st is a Friday, the First week of the year starts on January 4th. If January 1st is a Wednesday, the first week of the year starts on December 30th of the previous year.
It is therefore possible to have the “first Monday of the year” not be “Monday of the first week of the year.” To define the former, it is simpler to combine “Day of the year” and “Day of the Week” conditions.
Day Interval icon Day Interval
Specifies an interval of valid days (between 1 to 31) in a month with a starting day, an ending day, and a step.
You can also specify that the iteration start from the end of the month or that only open days are counted in each step. Open days are those days not specified by a condition or rule that closes or excludes dates.
For example, the last day of the month is specified by the interval beginning and ending with 1 with Reverse selected. The last weekday of the month would be specified when the Open check box is also selected and a Weekday Interval specifying Monday through Friday is added with an And operator.
Day of the Year Interval icon Day of the Year Interval
Specifies an interval of valid days (between 1 and 366) in a year with a starting day, an ending day, and a step. The day 366 is valid on leap years.
You can also specify that the iteration start from the end of the year or that only open days are counted in each step. Open days are those days not specified by a condition or rule that closes or excludes dates.
For example, you can specify winter as the interval from December 21st to March 20th.
Or for a slightly more complicated example, to specify every 10th day throughout the entire year, you could use a range from 1 to 365 (or 366 for a leap) with a step of 1. You could specify the last ten open days of the year with a starting day of 1, an ending day of 10, with Reverse and Open selected.
Day of the Week Interval icon Day of the Week Interval
Specifies one or more days of the week (from Monday through Sunday) as an interval with a starting day, an ending day, and a step.
For example, weekends are specified by the interval beginning on Saturday and ending on Sunday with a step of 1.
Weekday of the Month icon Weekday of the Month
Specifies a weekday in an indexed week of a particular month. The week is indexed from either the beginning or the end of the month.
Weekday of the Year icon Weekday of the Year
Specifies a weekday in an indexed week of the year. The week is indexed from either the beginning or the end of the year.
