The Bulk Agent Removal dialog appears when you lock the Domain, right-click the Domain and select Bulk Agent Removal. Administrators specify search criteria that includes the agents that are candidates for removal. From the search results, administrators indicate the agents to remove and then click the Delete button.
Note: Removing the agent reference does not uninstall the agent from the host. You can delete the agents that are active or inactive from the domain.
Contains controls for defining the search request. Select one of the radio buttons and optionally enter a search expression.
Indicates that the specified Search expression is an IP address pattern. For example, 10.131.91.0/24.
Indicates that the specified Search expression is a host name pattern.
Defines an expression that includes all agents that you want to remove. Leave the field blank to return all agents
Lists all agents that match the search criteria.
Lists the search results by Agent Name, Agent Host Name, IP Address and Status, where each row is preceded by a check box.
Selected - Remove this agent reference from the CA Process Automation Domain.
Cleared - Do not include this agent in the bulk agent removal.
Copyright © 2014 CA.
