Set Up a Load Balancer for Orchestrator Clustering › Apache Load Balancer › Configure Apache Load Balancer for Agent Scalability
You can configure the Apache load balancer to increase the number of agents in a cluster setup for secure and non-secure communication.
- Make the following changes in the workers.properties file:
- Add "uiloadbalancer" in the list of workers that are used for mapping requests as follows:
worker.list=uiloadbalancer, loadbalancer, status
- Add the following entries to define load balancing behaviour for UI calls:
worker.uiloadbalancer.type=lb
worker.uiloadbalancer.balance_workers=node1
worker.uiloadbalancer.sticky_session=1
worker.uiloadbalancer.retries=1
- Change the value of the following entry to "0":
worker.loadbalancer.sticky_session=0
- Change the value of the following entries to "uiloadbalancer" in the uriworkermap.properties file:
- /jmx-console
- /jmx-console/*
- /web-console
- /web-console/*
- /itpam/*
- /itpam
- /c2orepository/oasisHelp
- /c2orepository/oasisHelp/*
- /c2orepository/htmlFile/aboutUs/*
- /c2orepository/htmlFile/language/*
- /itpam/OasisPrimary
- /itpam/JNLPRequestProcessor/installation
- /itpam/clientproxy/c2oresourceaction
- /itpam/clientproxy/c2oreportaction
Note: A new installation of CA Process Automation does not require any manual changes in the workers.properties and uriworkermap.properties files. For more information, see Install a Load Balancer and Prepare Configuration Templates (Windows).
Copyright © 2014 CA.
