Previous Topic: How to Improve Performance of CA Process AutomationNext Topic: Use CA SiteMinder with CA Process Automation
Tuning CA Process Automation by Editing Configuration Files
JVM Tuning
Consider doing JVM tuning.
  1. Log in to the server where an Orchestrator is installed.
  2. Navigate to the following folder:
    install_dir/server/c2o/bin/
  3. Open the following file:
    c2osvcw.conf
  4. Edit the following parameters as shown:
    wrapper.java.additional.7=-XX:PermSize=256m
    wrapper.java.additional.8=-XX:MaxPermSize=768m
    wrapper.java.initmemory=4096
    wrapper.java.maxmemory=4096
    Note: The wrapper.java.initmemory and the wrapper.java.maxmemory values must be identical. If additional memory is required and available on the server, these values can be changed.
  5. Save the updated c2osvcw.conf file.
JBOSS JMS and Database Pools Tuning
Consider updating default values for JBOSS JMS and Database pools.
    install_dir/server/c2o/conf/
    install_dir/server/c2o/conf/standardjboss.xml
  4. Edit the following parameter as shown:
  5. Save the updated standardjboss.xml file.
More information:
Example: Upgrade Any Node of the Domain Orchestrator from 3.1 SP01 to Release 4.2 on Windows
Example: Upgrade Another Node of the Domain Orchestrator from 3.1 SP01 to Release 4.2 on Windows
