Previous Topic: Start an AgentNext Topic: Offline Configuration of Agents to a Different Domain
Stop an Agent
You can stop a CA Process Automation agent running on a UNIX or Linux host.
Stop an agent on a Microsoft Windows host
The following steps apply to any agent in your CA Process Automation domain that resides on a host with a Windows operating system.
  1. Log on to Windows host on which an agent is installed.
  2. From the Start menu, select Programs, CA, CA Process Automation Agent, Stop Agent Service.
  3. Log off the host.
Stop an agent on a Linux host
The following steps apply to any agent in your CA Process Automation domain that resides on a host with a UNIX or Linux operating system.
  1. Log on to the UNIX or Linux host on which an agent is installed.
  2. Change directories to:
    usr/local/CA/PAMAgent/pamagent
  3. Run the following command:
    ./c2oagtd.sh stop
    The agent stops running.
