nginx_install_dir/conf
This folder contains nginx.conf file.
server {
listen 80;
server_name <LOADBALANCER_HOSTNAME>;
location / {
root /usr/share/nginx/html;
index index.html index.htm;
This folder contains pam-server.conf file.
server <Enter node1 hostname here>:<http port> max_fails=3 fail_timeout=3s
Note: Defines the HTTP port that is used for the web server if the Support Secure Communication check box is cleared. This port is part of the URL that is used to access CA Process Automation web services and the CA Process Automation login screen.
server <Enter node1 hostname here>:<server port> max_fails=3 fail_timeout=3s
server <Enter node1 hostname here>:<server port> max_fails=1 fail_timeout=3s
Note: Defines the port that the Domain Orchestrator uses to communicate with other Orchestrators and agents.
Replace the Enter node1 hostname here placeholders with a valid value. Do not change the port numbers unless you use a different port for the CA Process Automation node. By default, the server port is configured to 8080 and the jetty server port is configured to 80.
Note: The valid values are the IP address, the FQDN, or the DNS alias that resolves to the host where you are installing the initial Domain Orchestrator node. The valid value is the same value that is used for “Server Host” when installing the Domain Orchestrator.
Repeat these steps for each additional node that you install.
include nginx_install_dir/conf/pam-server.conf;
This entry links NGINX with the configuration changes you made for CA Process Automation in the pam-server.conf file.
include nginx_install_dir/nginx/conf.d/*.conf;
Important! Perform the rest of these steps after you install at least one Orchestrator node. See Interactive Domain Orchestrator Installation or Unattended Domain Orchestrator Installation for instructions.
service nginx restart
The changes take effect.
Copyright © 2014 CA.
