Once NGINX is installed, extract the template files from the CA Process Automation installation media to your NGINX installation directory.
install_dir/DVD1/NginxConfTemplates
Used for non-secure configuration (HTTP).
Used for secure configuration (HTTPS).
Used for REST configuration (enables the inbound PAM Rest interface).
These files are specific to CA Process Automation configuration with NGINX.
nginx_install_dir/conf
You can now configure the NGINX load balancer.
Copyright © 2014 CA.
