Previous Topic: Ports Used by the Load BalancerNext Topic: Ports Used by an Agent
Ports Used by an Orchestrator
The following tables provide an overview of the ports used for communications, specifically:
Communication from an Orchestrator to another Component
From
Port
To
Default Listening Port
Protocol
Configuration
Description
Orchestrator
Any
CA EEM
5250
TCP
CA EEM configuration
Used to validate credentials and permissions (authentication and authorization)
Orchestrator
Any
Agent
7003
HTTP/ HTTPS
Specified during agent install or re-install
Deprecated
Agent listens on this deprecated port when using the old mode of communication with Orchestrators
Orchestrator
Any
Microsoft SQL Database Server
1433
TCP
Microsoft SQL configured
The database port can be changed in the database server installation; 1433 is the default value.
Orchestrator
Any
MySQL Database Server
3306
TCP
MySQL configured
The database port can be changed in the database server installation; 3306 is the default value.
Orchestrator
Any
Oracle Database Server
1521
TCP
Oracle configured Listener
The database port can be changed during Create Listener; 1521 is the default value for the Oracle Listener port. The database instance can be associated with a different listener. Refer to the Oracle configuration.
Communication between Domain Orchestrator and Non-Domain Orchestrator
From
Port
To
Protocol
Configuration
Description
Orchestrator
Any
7001
HTTP/ HTTPS
OasisConfig.properties
Port used for communication between Orchestrators.
Any
Domain Orchestrator
8080
TCP
OasisConfig.Properties
Basic Orchestrator to Orchestrator communication
Any
Domain Orchestrator
8443
TCP
Secure Orchestrator to Orchestrator communication
Any
Domain Orchestrator
80
TCP
Any
Domain Orchestrator
443
TCP
Communication between Clustered Orchestrator Nodes
From
Port
To
Protocol
Configuration
Description
Orchestrator
Any
Orchestrator
1090
TCP
JBoss Remoting port is used only between Orchestrators.
Orchestrator
Any
Orchestrator
1098
TCP
JBoss RMI port is used only between Orchestrators.
Orchestrator
Any
Orchestrator
1099
TCP
JBoss JNDI port is used only between Orchestrators.
Orchestrator
Any
Orchestrator
1100
TCP
JBoss: HA_Java Naming and Directory Interface is used only between Orchestrators.
Orchestrator
Any
Orchestrator
1101
TCP
JBoss: HA-Java Remote Method Invocation is used only between Orchestrators.
Orchestrator
Any
Orchestrator
1102
UDP
JBoss: JNDI Autodiscovery service is used only between Orchestrators.
Orchestrator
Any
Orchestrator
3873
TCP
JBoss: EJB3 Remoting Connector is used only between Orchestrators.
Orchestrator
Any
Orchestrator
4444
TCP
JBoss RMI Server port is used only between Orchestrators.
Orchestrator
Any
Orchestrator
4445
TCP
JBoss Pooled Invoker port is used only between Orchestrators.
Orchestrator
Any
Orchestrator
4446
TCP
JBoss HA Pooled Invoker port is used only between Orchestrators.
Orchestrator
Any
Orchestrator
4447
TCP
JBoss HA-RMI Server port is used only between Orchestrators.
Orchestrator
Any
Orchestrator
4448
TCP
Orchestrator
Any
Orchestrator
4457
TCP
JBoss Messaging port is used only between Orchestrators.
Orchestrator
Any
Orchestrator
4712
TCP
JBoss Transaction Status Recovery Manager port is used only between Orchestrators
Orchestrator
Any
Orchestrator
4713
TCP
JBoss Transaction Status Manager port is used only between Orchestrators.
Orchestrator
Any
Orchestrator
7600
TCP
JBoss clustering port is used only between Orchestrators.
Orchestrator
Any
Orchestrator
7900
TCP
Orchestrator
Any
Orchestrator
7901
TCP
Orchestrator
Any
Orchestrator
8083
TCP
JBoss RMI WebService port is used only between Orchestrators.
Orchestrator
Any
Orchestrator
61618
TCP
ActiveMQ messaging subsystem.
Note: CA Process Automation uses JBoss 5.1, which listens on a random set of dynamic ports in the range (49152-65535). The dynamic ports are required for various features, including cluster node communication. If CA Process Automation cannot communicate on these ports, functionality may be severely limited (for example, processes may become stuck).
CA recommends that nothing be placed between cluster nodes that could block communication. If a firewall is required, CA recommends that you open all TCP ports in both directions between the cluster nodes for the java.exe process that is associated with CA Process Automation.
Communication to a Clustered Orchestrator from another Component
From
Port
To
Protocol
Configuration
Description
Load Balancer
Any
Orchestrator
8080
HTTP
Oasisconfig.properties
Load Balancer talks to Orchestrator on this port.
Load Balancer
Any
Orchestrator
8443
HTTPS
Load Balancer talks to secure Orchestrators on this port.
Load Balancer
Any
Orchestrator
7000
HTTP
node0-config.xml
CA Process Automation Catalyst REST API port
Load Balancer
Any
Orchestrator
7443
HTTPS
node0-config.xml
CA Process Automation Catalyst REST API secure port
Load Balancer
Any
Orchestrator
8009
TCP/AJP
Loadbalancer - AJP connector port between Load Balancer and Orchestrator.
This port does not apply to NGINX.
Agent
Any
Orchestrator
8080
HTTP
Deprecated communications only
Agent
Any
Orchestrator
8443
HTTPS
Agent
Any
Orchestrator
7001
HTTP/ HTTPS
Deprecated port
Communication to a Non-Clustered Orchestrator from another Component
From
Port
To
Protocol
Configuration
Description
Orchestrator
Any
Orchestrator
443
HTTPS
Jetty
Web-socket connection established by agents
Agent
Any
Orchestrator
8080
HTTP
Agent
Any
Orchestrator
8443
HTTPS
Agent
Any
Orchestrator
80
HTTP
Basic Server Port
Agent
Any
Orchestrator
443
HTTPS
Secure Server Port
Agent
Any
Orchestrator
7001
HTTP/ HTTPS
Deprecated port
Web Browser (CA Process Automation Web UI user)
Any
Orchestrator
8080
HTTP
Browser talks to Orchestrator on this port with basic communication.
Any
Orchestrator
8443
HTTPS
Browser talks to secure Orchestrators on this port.
Web Services (SOAP) client
Any
Orchestrator
8080
HTTP
Orchestrator SOAP API server
Any
Orchestrator
8443
HTTPS
Orchestrator SOAP API server (secure)
