Previous Topic: Prerequisites to Installing the Domain OrchestratorNext Topic: Database Prerequisites
Planning the Locations of Supporting Components
Part of planning a CA Process Automation system is determining what new components you can colocate on the same host with the CA Process Automation Domain Orchestrator and which ones to install on separate hosts. Let us consider these components of a CA Process Automation network.
Each cluster node and each Orchestrator is typically installed on a separate host. The NTP server can be external to the network.
For a lightly loaded CA Process Automation, you could install the following entities on the same host on which you installed the Domain Orchestrator:
Consider the following factors when determining whether to colocate entities or use multiple hosts:
In anticipation of future growth, we recommend against colocating CA EEM and the database with the Domain Orchestrator. The only sure way to determine when you have enough resources is by actual full load testing.
