Previous Topic: Database Owner PrivilegesNext Topic: Setting the Default Java Home Path
JDK Prerequisites
Before you install any Orchestrator, verify that the Java Development Kit (JDK) prerequisites are met. Use the following command:
Java -version
Get java version 1.7.0_45
The preceding example shows a valid Java version for Windows.
  1. Log in to host where you plan to install the Domain Orchestrator.
  2. Verify that your Java Development Kit is Oracle JDK 1.7.
    Note: For other details, see Platform Support and Requirements for CA Process Automation Components. If default Java version is different, change the default Java version on the shell where you will start the CA Process Automation installer.
  3. If the required JDK version is not installed, download it from the Oracle website and run the installation wizard to install the JDK.
  4. For a clustered Orchestrator, ensure that Oracle JDK is installed on each node.
