Previous Topic: Post-installation Support for CA EEM UpgradesNext Topic: Install Agents
Enable Secure Communications for an Existing CA Process Automation System
If you previously selected HTTP as the protocol over which the Domain Orchestrator communicates, you can begin communicating over the secure HTTPS protocol.
  1. Reinstall the Domain Orchestrator. Specify secure communication in one of the following ways, depending on your installation method:
  2. Enable secure communication by agents in one of the following ways, based on their configuration.
    HTTPS is used for all the communication between agents and the Domain Orchestrator.
  3. Verify that all process instances that are using existing SOAP attachments are complete.
    Note: Existing SOAP attachments are accessible over HTTP only.
