Previous Topic: Configure Firewalls for Bi-directional CommunicationNext Topic: Enable NTLM Pass-Through Authentication After Installation
Install Drivers for Database Operators
CA Process Automation designers can use operators from the Database category (formerly the JDBC module) to connect to various Relational Database Management Systems (RDBMSs). When the connection is to a MySQL database, an Oracle database, or a Microsoft SQL Server database, the correct drivers are available. (Availability of all three drivers depends on your selection during the Domain Orchestrator installation.) When the connection is to a database from a different vendor, you can deploy the JDBC driver for Database operators for that database from the CA Process Automation Configuration tab. For example, if a designer wants to use the Database operators for Sybase, an administrator deploys the JDBC drivers for Sybase. An administrator can deploy JDBC drivers on Orchestrators or on hosts with CA Process Automation agents.
Note: See How to Deploy JDBC Drivers for Database Operators in the Manage User Resources chapter of the Content Administrator Guide for procedures.
