Specifies the location to save the file locally. For example: /IT PAM/import/script_ora1.sh.
The location must be valid at run time on the touchpoint running the File Transfer operators.
When you use Windows file nomenclature, backslashes must be escaped as follows:
C:\\IT PAM\\import\\script_ora1.bat
We recommend using “normalized” file names, with slash marks (/), even when specifying a path on a Windows host. For example: C:/IT PAM/import/script_ora1.bat.
Specifies the full path for the file on the remote FTP host. For example: /tmp/IT PAM/scripts/script_ora1.sh.
Specifies the IP address or FTP URL for the remote host. For an FTP site on your company intranet, you can specify the server name (//servername) for the FTP site.
By default, FTP sites use port 21. However, you can assign a private port to an FTP site. Private ports range from 49152 to 65535. To specify a private FTP port, add a colon (:) and then a private port number to the end of the address. For example, the following specifies port 50021 on a remote FTP server:
172.24.36.107:50021
Specifies the user ID to access the remote FTP host.
Specifies the password to access the remote FTP host.
Uses the SITE command to invoke services that are specific to the host system. Then use the SITE parameters field to specify a CA Process Automation expression that returns parameters for the SITE command. This option is used, for example, to dimension files on a target MVS system.
Enter a CA Process Automation expression that returns parameters for the SITE command.
Copyright © 2014 CA.
