Previous Topic: Secure Upload File OperatorNext Topic: Remote Login Information
Input Parameters
Local file
Specifies the full path for the local file to transfer. For example: C:\\IT PAM\\import\\script_ora1.sh. This option is unavailable if you select the Is inline data check box.
Is inline data
When selected, transfers text stored with the operator in the library. Click the Inline data field to enter data.
Inline data
Click this field to open the Inline data editor where you can enter the data to transfer.
Remote file
Specifies the path for the file on the remote FTP host. For example: /tmp/IT PAM/scripts/script_ora1.sh. If you do not specify a file name, the operator saves the file using the same name as the copied file. The location must be valid at run time on the touchpoint running the File Transfer operators.
Remote host
Specifies the IP address or FTP URL for the remote host. For an FTP site on your company intranet, you can specify the server name (//servername) for the FTP site.
By default, FTP sites use port 21. However, you can assign a private port to an FTP site. Private ports range from 49152 to 65535. To specify a private FTP port, add a colon (:) and then a private port number to the end of the address. For example, the following specifies port 50021 on a remote FTP server:
172.24.36.107:50021
Remote user ID
Specifies a user ID to access the remote FTP host.
Remote user password
Specifies the password to access the remote FTP host.
Specify an optional SITE command
Select this check box to use the SITE command to invoke services that are specific to the host system. Then use the Site parameters field to specify a CA Process Automation expression that returns parameters for the SITE command.
Site parameters
Enter a CA Process Automation expression that returns parameters for the SITE command.
