Previous Topic: Input ParametersNext Topic: Sort Criteria
Get Criteria
Start Search Path
Specifies the start location for the search, Like CN=Users,dc=domainpart,dc=company-name,dc=top-level-domain-name.
Retrieve Scope
Select one of the following options:
Subtree Scope
Searches the entire subtree (including the object at the search path).
One Level Scope
Searches the objects directly under the object at the search path.
Object Scope
Searches the object at the search path only.
Results Limit Count
Maximum number of entries to return.
Time Limit for Retrieve
Specifies time in seconds to wait before timing out of this search.
If 0 or nothing is entered, there is no time limit set on the search.
Retrieve Filter
Specifies the search filter to use for this search.
Retrieve Attributes specified as an Array Variable?
Check this box to supply a dataset variable that contains an array of attributes to retrieve.
Retrieve Attributes Array Variable
Specifies the dataset variable that supplies an array of attributes to retrieve. This field is enabled when the Retrieve Attributes specified as an Array Variable? check box is enabled.
Retrieve Attributes List
Specifies a list of attributes to retrieve for this search filter. This list is enabled when the Retrieve Attributes specified as an Array Variable? field is unchecked.
