Previous Topic: Add Attributes Parameters PageNext Topic: Remove Attributes Parameters Page
Replace Attributes Parameters Page
Use the Replace Attributes Parameters page to enter all the attributes whose values you want to replace in the LDAP object.
Use specified array fields for the LDAP attributes to be added
If this is checked, then the Attributes and Attributes Values arrays will be used for this request.
LDAP Attributes Array
Specifies the array containing the LDAP names of the attributes whose values are to be replaced in the object. This Dataset field must be defined as an array (indexed string). If Use specified array fields for the LDAP attributes to be added is checked, this field will be used.
LDAP Attributes Values Array
Specifies the array containing the new values of the attributes to be replaced in the object. This Dataset field must be defined as an array (indexed string). If Use specified array fields for the LDAP attributes to be added is checked, this field will be used.
LDAP Attributes
Specifies the LDAP names of the attributes whose values are to be replaced in the object. If Use specified array fields for the LDAP attributes to be added is unchecked, this field will be used.
Specifies the new values of the attributes to be replaced in the object. If Use specified array fields for the LDAP attributes to be added is unchecked, this field will be used.
LDAP Attributes Value Maps
Specifies an array of value maps containing the LDAP names and new values of the attributes whose values are to be replaced in the object. Each value maps Key and Value must be of type string; moreover, the key must be named Keys and the value must be named Values.
