Previous Topic: setProcessProgressNext Topic: today
setResourceTotal
The setResourceTotal function sets the total amount of resources with the resource name "resName" to the "amount" specified in the resource object on the path "resPath".
Notes:
Syntax
bSuccess = setResourceTotal(resPath, resName, amount)
Arguments
resPath (String)
Specifies the path of the resource object.
resName (String)
Specifies the resource name that you set in the resources object.
amount (Int)
Specifies the total amount that you set on the resource.
Return Value
bSuccess (Boolean)
Returns true if the function is successful or false if the function fails.
Example
bSuccess1=setResourceTotal(Process.ResObjName, Process.ResName_1, 1);
bSuccess2=setResourceTotal(Process.ResObjName, Process.ResName_3, 3);
