Previous Topic: Specify System Dataset VariablesNext Topic: Variable Declaration
Statements
Expressions are JavaScript phrases that are evaluated to yield a value. JavaScript statements execute commands or combine one or more expressions to do things or yield values. A JavaScript program is a collection of statements.
This section briefly describes variable declaration and variable assignment, iterations, and loops that are commonly used in CA Process Automation calculations. The following table lists JavaScript statements, some of which are not documented in this section.
JavaScript Statements
Statement
Syntax
Description
break
break; break label_name:
Exit from a switch or iterative statement; or exit from the statement named by a label statement.
case
case expression:
Labels a statement within a switch statement.
continue
continue; continue label_name:
Restart the loop, or the loop named by a label statement.
default
default;
Label the default statement within a switch statement.
do/while
do statement while (expression)
Perform expressions in a while statement until an expression evaluates False.
empty
Do nothing.
for
for (initialize ; test ; increment) statement
Loop while a test is True.
for/in
for (variable_in_object) statement Loop through properties of an object.
See “The for/in Loop Statement."
function
function function_name(a1,a2,...an) {statements}
Declares a function. See “Include Common Resources in CA Process Automation Scripts” .
if/else
if (expression) statement1 else statement2
Execute conditionally. See “The if Statement.”
label
identifier: statement
Assign an identifier to a statement.
return
return[ expression];
Return from a function or return a value from a function.
switch
switch (expression) { statements }
Multiway conditional branch to case or default statements. See “The switch Statement.”
throw
throw expression;
Throw an exception.
try
try { statements }
Catch an exception.
var
var name_1[=value1][, ..., name_n [=value_n]];
Declare and optionally initialize variables. See “Variable Declaration.”
while
while (expression) statement
Perform expressions in a while statement while an expression evaluates True. See “The while Loop Statement.”
More information:
The if Statement
The while loop Statement
