Previous Topic: Document a ProcessNext Topic: Set the Name for an Operator in a Process
Add Comments to a Process
Use the Comment operator in the Standard group of the Operators palette to add comments to a process. You can change the Name property string for the operator. Comments are important for documenting steps in a process and allow more space than labels.
To add a comment to a process
  1. Drag a Comment operator from the Standard group onto the process.
    A comment object appears with a default name of Comment.
  2. Double-click the comment to open the Comment Properties dialog.
  3. Replace the initial text of the comment with the text that you want to appear on the canvas.
    You can change the background color, text format, and alignment.
  4. Click OK to apply your changes.
  5. Click Save to save your process design.
