The Oasis Configuration properties file (OasisConfig.properties) contains the property settings for all aspects of CA Process Automation. The file is located in the install_dir/server/c2o/.config folder. All users with access to the CA Process Automation installation location can modify the files. Consider restricting access to this location. Some values must not be edited.
Settings include:
(For agents only) Determines during the start of an agent whether it uses the new mode of communication or deprecated mode of communication. This is a boolean value.
When the Use Deprecated Communications check box in an agent's properties is selected, this value is set to true. CA Process Automation:
When the Use Deprecated Communications check box in an agent's properties is not selected, this value is set to false.
See About Agent Communication for more information.
Defines the unique ID for the Domain.
ac04f945-f08b-4308-aa9c-c3fd95964f4d
Determines a node uniquely in a cluster.
8d11558a-3bf7-43d9-b394-4c055229e9ae
Defines the password of the keystore.
Defines the path of the keystore that is used for signing jars.
C:/Program Files/CA/PAMcert_Java7_Node2/server/c2o/.config/c2okeystore
Defines the password of the keystore that is used for signing jars.
LQotQj55Y8dPGRRXkrF4yTyk/IwzTcT0rLY+pWeGrGHaRKnlcXHL3fr7pYIzjVhoGdrnRxSO4Prl70rIxqs3fCGIgFVIAnOzICQ9ct4qXIBIPnxQcgflrF0WDdaIjCS6ubKwe9Wxhn0xjnmctvkLnMC1L74b48yQd9yhWSMAgpLAPLPJiMz/VoIzcFVylqLS44KdM+wH6b6xkqVJECSH1GolBG2QUj/2
Defines the alias name of the certificate in the keystore that is used for signing jars.
ITPAM
Defines the password that is used to control access to the keystore that is used to encrypt passwords and other critical data.
XNASLujiOdl6POYm8CwjBTHnFUlbXQLcPqd+xc7oJkPF5X3cq8UHbEYL4iH+01b1EmwHhw9uPXqDABcJqIJ+ECmODDAMn7rytSWqli+oxKp+e5scp1fnHjF1ENCKZNasYy6nF6vPozT9qLmB7DhzuFAvg8Av9J/U4ngYrZ5AMdU1sFP5Ddf3nw==
Defines the user name for the Library database server.
sa
Defines the password that is associated with the specified library database server user.
SSb28pTxSL4fxuv+8IV8zLz+S6jwleU4mpQTDTM1xmwQ037qmAjDO74Y569W3LIP0vBUEkJ30raf3/RsodMLdL3L51cnz8Gus4mJfGJla7WdTtzx0ts0BuUFPxZ1pOpHOUUljFHn73243Iv7/pXIQe+O8lrHB00XotDicrleXavs+8sXSIPqKyX3gmjy6LUZ
Defines the host name of the library database server.
lodivsa205
Defines the Library database server connection port number.
1433
Defines the Library database JDBC connection URL.
jdbc:sqlserver://lodivsa205:1433;databaseName=
Defines the type of library database.
MSSQLServer2005
Defines the user-defined dialect class of the library database.
com.optinuity.c2o.persistence.MSQLServerDialect
Defines the dialect class of the library database.
org.hibernate.dialect.SQLServerDialect
Defines the fully qualified name of the JDBC driver class.
com.microsoft.sqlserver.jdbc.SQLServerDriver
Defines the type mapping for the datasource.
MS SQLSERVER2000
Defines a class that implements the org.jboss.resource.adapter.jdbc.ExceptionSorter interface. The interface examines database exceptions to determine whether they indicate a connection error.
org.jboss.resource.adapter.jdbc.vendor.SybaseExceptionSorter
Defines a class that implements the org.jboss.resource.adapter.jdbc.ValidConnectionChecker interface. The interface provides a SQLException isValidConnection(Connection e) mode. The application calls the mode with a connection that is returned from the pool to test its validity.
org.jboss.jca.adapters.jdbc.extensions.mssql.MSSQLValidConnectionChecker
Defines the datasource class.
com.microsoft.sqlserver.jdbc.SQLServerXADataSource
Defines parameters that are used to create the database connection.
responseBuffering=full;SelectMethod=cursor;
Defines the name of the library database.
pamgacert_cluster_JDK7_rep
Defines the name of queues database.
pamgacert_cluster_JDK7_run
Defines the type of reporting database.
MSSQLServer2005
Defines the user name for the reporting database server.
sa
Defines the password that is associated with the specified user for the reporting database server.
oIzz9oH5OU4XRkOaeLblNqEYDsaXNGiMg9LSy2P7gsVLG0ea32nBlUIvXgEXhiKfGzIbCmYFgYoFg0sVBlnY/k1sAeZ21z20sw5Yr9HC2B3+IRoyy5LXCmByMUMc7Ywq/BocPnw4e1DBDDfGqCQL/6ciK4CT1C7hU/V3Y4Ktrc9IsPK1aXeNRM1qvpVwBAtG
Defines the host name of the reporting database server.
lodivsa205
Defines the reporting database server connection port number.
1433
Defines the dialect class of the reporting database.
Defines the type mapping for the data source.
MS SQLSERVER2000
Defines the user-defined dialect class of the reporting database.
Defines an SQL statement to run on a connection before it returns from the pool to verify its validity to test for stale pool connections. For example: select count(*) from x.
select 1
Defines the reporting database JDBC connection URL.
Defines the additional parameters to use for creating the database connection.
;responseBuffering=full;SelectMethod=cursor;
Specifies whether the CA Process Automation server is FIPS-compliant.
true
Defines the name of the reporting database.
pamgacert_cluster_JDK7_rpt
Defines the runtime database type.
MSSQLServer2005
Defines the user name for the runtime database server.
sa
Defines the password that is associated with the specified user for the runtime database server.
SOIjQ79jp66tm5E7ZYxLV2yqtVV54HRVs+xvNksG7p1pzTZOoOXahwS0XOcVoMl8MznkgQgVOllCIU/YBx6lT3ZAxnzOMY2xBQnIp5xTxw0Dv5eqqTvpOnm6P2vPOS1RzYGA6GRt3VdASiTZwZs/BkIX/sY+6C52V/x5Eg7l4hff6/6gS6wvRHdJG/sXU6D6
Defines the host name of the runtime database server.
lodivsa205
Defines the runtime database server connection port number.
1433
Defines the user-defined dialect class of the runtime database.
Defines the dialect class of the runtime database.
MS SQLSERVER2000
Defines a class that implements the org.jboss.resource.adapter.jdbc.ExceptionSorter interface to examine database exceptions to determine whether the exception indicates a connection error.
select 1
Defines a class that implements the org.jboss.resource.adapter.jdbc.ValidConnectionChecker interface to provide a SQLException isValidConnection(Connection e) method. A connection that returns from the pool calls this method to test its validity.
Defines the data source class.
Defines the SQL statement to use to create the properties table if it is not present. The user is not expected to modify this statement because the application configures the correct value for the relevant database by default.
Example
create table properties (propkey varchar(255) NOT NULL,propvalue NVARCHAR(MAX),PRIMARY KEY (propkey))
Defines the runtime database JDBC connection URL.
Defines the additional parameters that are used to create the database connection.
Defines the runtime database driver name.
com.microsoft.sqlserver.jdbc.SQLServerDriver (for a MSSQL database)
Defines the name of the runtime database.
Defines the type of security server that is used for authentication and authorization.
EEM
Defines the type of login policy.
EEM
Defines the path of the folder that contains the security certificate. The path is relative to the c2o folder.
install_dir/server/c2o/.c2orepository/public/certification/
Defines the host name of the computer that hosts the EEM security server.
lodivsa205
Defines the application name in the EEM server on which the policies are defined for the current CA Process Automation instance.
Specifies whether the EEM server is running in FIPS mode.
false
Defines the name of the security certificate.
PAM.p12
Defines the name of the security certificate key file that is used for authentication. This property is only applicable if isFipsMode=true.
PAM.key
Defines the password that is associated with the EEM security certificate. This property is only applicable if isFipsMode=false.
dD65vFTVmbn8aaZxjot9QCUIfPEey1H8/KGtNShgrronJk0rMtqliDMrNo2VE+xoAUDcfmT9IPCQsAe497w1xUBkHg8PbZNjWVkPpFYw496eFiwiq7AoyB8WCoUrx8wVnkMjoGs1BqDND+kjHcnUt9HLljYgxatT7Q2FpbTA7+Qag0W9gSv2oH4iBsUjVs22
Specifies whether NTLM authentication is enabled. When changing this port, remove the .c2o folder in the ${Installation Dir}/server/c2o/.system folder, if it exists.
Defines the port to use for communication with other Orchestrators or agents.
7001
Defines the host name of the computer that is used for communication with the Orchestrator or agent.
name03-I40136.ca.com
Defines the host name of the computer where CA Process Automation is installed.
Specifies whether this CA Process Automation instance is clustered.
true
Defines the name of this node in the cluster. This property is applicable only if it is a part of cluster.
node2
Defines the listening port for SNMP triggers.
162
Specifies whether communication is secure.
true
Specifies whether to accept all certificates in secure communication.
true
Specifies whether to reject an interaction form which has not been configured for approval.
true
Defines the timeout (in minutes) for CA Process Automation. The timeout is the interval CA Process Automation can be idle, after which the session expires.
30
Defines the number of retries for authentication when the security server is EEM.
3
Defines the SSL protocol type. If the Java vendor is IBM Corporation, SSL protocol is used. Otherwise, TLS is used.
TLS
Defines the algorithm that is used for SSL certificates. If the Java vendor is IBM Corporation, the algorithm that is used is IbmX509. Otherwise, SunX509 is used.
SunX509
Defines the name under which this CA Process Automation instance is licensed.
CA
Defines the multicast address for this cluster node.
228.1.46.192
Defines the port of the RMI naming service.
1098
Defines the listening port for the bootstrap JNP(JNDI Provider) service.
1099
Defines the port that is used for the simple HTTP service that supports requests for classes for RMI dynamic class loading, org.jboss.web.WebService.
8083
Defines the RMI server socket listening port to which RMI clients connect when communicating through the proxy interface.
4444
Defines the pooled invoker server bind port.
4445
Defines the remoting server bind port.
4448
Defines the port on which the HA-JNDI stub is made available.
1100
Defines the RMI port that the HA-JNDI service uses when bound.
1101
Defines the RMI object port that JRMPInvokerHA uses.
4447
Defines the pooled invoker HA server bind port.
4446
Defines the multicast group port that is used for JNDI autodiscovery. This port is defined in cluster-service.xml and hajndi-jms-ds.xml in deploy/jms.
1102
Defines the multicast UDP port for HAPartition. This port is defined in cluster-service.xml and jmx-console.war/WEB-INF/web.xml.
45566
Defines the multicast UDP port for HttpSession replication. This port is defined in tc5-cluster-service.xml.
45567
Defines the port for the connector component that supports the HTTP/1.1 protocol. This property enables Catalina to function as a stand-alone web server, in addition to its ability to run servlets and JSP pages. The Port is also configured in jboss-ws4ee.sar/META-INF/jboss-service.xml for Axis SService.
8080
Defines the port for the connector component that communicates with a web connector through the AJP protocol.
8009
Defines the secure port that the SSL connector uses. This port is unused. This port is the same port that is configured as:
The port is of use only if the SSL connector is enabled.
8443
Defines the port to which Unified Invocation Layer (UIL) service clients connect when they establish a connection to the JBossMQ server.
8093
Specifies the CA Process Automation protection level. In secure mode, the protection level is set to CONFIDENTIAL, otherwise it is set to NONE.
Values: NONE, INTEGRAL, or CONFIDENTIAL.
Defines the initial heartbeat frequency (in minutes).
2
Defines the encoding of this system.
Cp1252
Defines the maximum number of records to search simultaneously in EEM.
10000
Defines a JBoss-related port.
3873
3528
3529
Defines the value of the temporary directory that runs scripts.
C:/Users/ADMINI~1/AppData/Local/Temp/2
Specifies whether the user selected an option to change the PowerShell run policy during installation.
false
Defines the PowerShell path on the host computer.
C:/Windows/System32/WindowsPowerShell/v1.0
Specifies whether to override the java.io.tmpdir system variable. The default value (true) lets the server refer the system variable to c2oHome/tmp. Set this property to false if you do not want the server to refer the system variable to c2oHome/tmp..
true
Defines the default stack type being set up for use by JGroups for the application to run on.
tcp
Defines the TCP port for TCP-based clustering in JBoss.
7600
Defines the TCP sync port for TCP-based clustering in JBoss.
7650
Defines the TCP-based messaging datachannel port.
7900
Defines the TCP-based messaging control channel port.
7901
Defines a nonnegative integer that the JBoss Transaction Service requires.
120000
Defines the time when the reaper starts timing out the ongoing transactions after timeout a timeout occurs. JBoss requires this property.
300
Defines the File Ref deploy/messaging/remoting-bisocket-service.xml. JBoss Messaging requires this property.
4457
Defines the File Ref deploy/jmx-remoting.sar. JBoss Remoting requires this property.
1090
Defines the communication transport to JBoss Messaging. JBoss Messaging 2 Netty requires this property.
5445
The JBoss. SSL version of Netty requires this property.
5446
Defines the File Ref deploy/transaction-jboss-beans.xml. JBossTS Recovery Manager requires this property.
4712
Defines the File Ref deploy/transaction-jboss-beans.xml. JBossTS Transaction Status Manager requires this property.
4713
Defines the File Ref deploy/transaction-jboss-beans.xml. JBossTS requires this property.
4714
Defines the name of the file that contains the Catalyst container payload.
catalyst.installer.payload.zip
Defines the name of the Catalyst container.
node0
Specifies whether the Catalyst Process Automation Services is enabled.
false
Specifies whether to override the payload (if the payload is present).
false
Defines the /container/etc/org.ops4j.pax.web.cfg port.
8181
Defines the host name of the Catalyst bus in /registry/topology/physical/node0/catalyst-bus/bus.properties.
localhost
Defines the port of the Catalyst bus in /registry/topology/physical/node0/catalyst-bus/bus.properties.
61616
Defines the HTTP port of the Catalyst bus in /registry/topology/physical/node0/catalyst-bus/bus.properties.
61617
Defines the maximum archive query results.
30
Specifies whether to use the Catalyst claims for credentials.
false
Defines a factory class for instantiating Loggers for Commons Logging.
org.apache.commons.logging.impl.Log4JLogger
org.apache.commons.logging.impl.Log4jFactory
This user-added parameter defines the maximum age (in seconds) of the cache that stores user credentials with the associated permissions profile. If set to zero, this CA Process Automation authorization cache is turned off and CA Process Automation sends a request to CA EEM each time user permissions are needed. When this parameter is missing, CA Process Automation uses 30 seconds as the refresh rate for the secondary cache.
Note: See Control the Refresh Rate of Caches of CA EEM Updates for details about the two CA EEM caches.
30
Lets you download an email with a specified amount of buffer.
K is the unit of measure. For example, if you specify 256, CA Process Automation defines it as 256K.
mail.attachment.buffer.size=256
This property is specific to IMAP protocol and is not introduced for CA Process Automation. This property lets you more quickly download large mail attachments.
Specify this property in bytes.
To specify 800k, multiply 800*1024.
mail.imap.fetchsize=819200
Specifies the property that Jboss Transaction Service uses. If XA resources are involved in multiple transactions, this property is false.
Enables or Disables the SNI Host Name Matching.
Defines the activeMQ Management Context port.
Defines the activeMQ Min JVM Heap.
Defines the tcp port of the activeMQ.
Defines the activeMQ Max JVM Heap.
Copyright © 2014 CA.
