JVM Tuning
Consider doing JVM tuning.
install_dir/server/c2o/bin/
c2osvcw.conf
wrapper.java.additional.7=-XX:PermSize=256m wrapper.java.additional.8=-XX:MaxPermSize=768m wrapper.java.initmemory=4096 wrapper.java.maxmemory=4096
Note: The wrapper.java.initmemory and the wrapper.java.maxmemory values must be identical. If additional memory is required and available on the server, these values can be changed.
JBOSS JMS and Database Pools Tuning
Consider updating default values for JBOSS JMS and Database pools.
install_dir/server/c2o/conf/
install_dir/server/c2o/conf/standardjboss.xml
<idle-timeout-minutes>10</idle-timeout-minutes> <prepared-statement-cache-size>250</prepared-statement-cache-size> <max-pool-size>375</max-pool-size>
<idle-timeout-minutes>10</idle-timeout-minutes> <max-pool-size>375</max-pool-size>
