You can change the URL of the Domain Orchestrator during a reinstall or you can make a port change to the existing URL through an OasisConfig.properties file change.
Symptom:
Agents that use simplified communication stop communicating with an Orchestrator after that Orchestrator URL is changed, including a change in port number.
Note: Simplified communication is configured by clearing the “Use deprecated communication” check box in the agent properties.
Solution:
Reinstall all agents that are associated with touchpoints in the environment with the affected Orchestrator.
