Upgrade to the Current Release › Upgrade a Cluster Node
When you upgrade a clustered Orchestrator, you upgrade one node at a time, beginning with any node in the cluster.
- Log onto the host on which a cluster node is installed.
- Browse to the Domain Orchestrator URL (the load balancer for the Domain Orchestrator, if clustered).
- Log in, click the Configuration tab, and then click the Installation palette.
- Under Install Cluster Node for Orchestrator, click Install to begin the upgrade.
- The language selection dialog appears first. Click OK.
- Click Next to the Welcome to the CA Process Automation 3rd Party Installer Setup Wizard page.
- For License Agreement, select I accept the terms of the license Agreement and then click Next.
- On the Select Destination Directory page, navigate to the directory you used for the previous release. For example, in Windows, the following are defaults, depending on the source release.
C:\program files\ca\itpam
C:\program files\ca\pam
- Click through the following Wizard pages:
- If you upgraded your JDK, browse to the Java Home Directory, for example, C:\Program Files\Java\jdk1.7.0_45
- Complete the Configuration Screen:
- If you have already upgraded a node in this cluster, select from the Orchestrator drop-down list the Orchestrator node that you upgraded first.
- Type node1, node2, node3, or node4 in the Load Balancer Worker Node field to identify the node you are upgrading.
- Type your company name, if not displayed
- Enter the certificate password.
Important! This entry must match the certificate password that was entered when the Domain Orchestrator was upgraded.
- Click through the following pages, if they appear. Settings used by node1 are used by other nodes in the cluster.
- Select Start Menu Folder.
- General Properties page (Install as Windows Service is not shown but is assumed).
- Scripts Temporary Directory
- PowerShell
- CA Embedded Entitlements Manager (CA EEM) Security Settings
- Database Settings - Repository
- Database Settings - Runtime
- Database Settings - Reporting
The upgrade installation begins.
- When Completing the CA Process Automation Setup Wizard page appears, click Finish.
Processing continues after you click Finish.
- When processing completes, start the Orchestrator service on the upgraded cluster node.
Note: See Start Orchestrators for operating system-specific details.
More information:
Example: Upgrade Any Node of the Domain Orchestrator from 3.1 SP01 to Release 4.2 on Windows
How to Upgrade CA Process Automation
Example: Upgrade Another Node of the Domain Orchestrator from 3.1 SP01 to Release 4.2 on Windows
