Upgrade to the Current Release › Test Your Processes with the Upgraded Orchestrators
After the upgrade is complete, test your processes with the upgraded CA Process Automation. Consider the following approach. Verify that processes run successfully on each of your Orchestrators.
- Start a process that generates a task. Take the task for yourself. Verify that the process instance appears on the Home tab. Verify that the task you took appears in your Task List.
- Start a scheduled process or operator. Verify that it starts on time and completes successfully.
- Start a process with operators that run on agent touchpoints or on remote hosts through proxy touchpoints. Verify that the process instance completes successfully.
- Allow solutions that use CA Process Automation as an integrated component to run. Monitor the results and verify that nothing unexpected occurs.
More information:
How to Upgrade CA Process Automation
