When you install the Domain Orchestrator or any nonclustered Orchestrator, you specify details for three CA Process Automation data stores: Library, Runtime, and Reporting. If you define the Type of Database as MS SQL, use the following guidelines to specify the Database Server:
A SQL Server named instance is another copy of SQL Server running on the same host. Each copy runs independently; each copy is distinguished by its instance name. A database server can have many named instances but only one default (unnamed) instance.
