Install the Domain Orchestrator › Uninstall the Domain Orchestrator
Only administrators with administrator credentials on the server where the Domain Orchestrator is installed can uninstall it.
Note: Stop the Domain Orchestrator before uninstalling it.
- Using the Administrator credentials, log in to host where the target Domain Orchestrator is installed.
- If you logged in to the following hosts:
- A Windows host:
You can uninstall the Domain Orchestrator from the Start menu and Control Panel. Perform one the following tasks:
- A UNIX or Linux host, perform the following tasks:
- Change directories to ${PAM_HOME}/standalone/. For example, change directories to:
/usr/local/CA/PAM/server/c2o
- Run the ./uninstall script.
The Uninstall wizard is displayed.
- After the Domain Orchestrator is uninstalled, verify the following changes:
- In Administrative Tools and Services from the Control Panel, the CA Process Automation Domain service is deleted.
- The CA Process Automation Domain entry is removed from the Start menu, Control Panel, Programs and Features.
- The Domain Orchestrator folder is removed from the Installation location.
