Install Agents › Post-installation Tasks for Agents › Resolve Port Conflict for an Agent
If a port becomes unavailable after an agent is installed, change the port assignment using one of the following approaches:
- Windows:
- Navigate to the following directory on the host where the agent is installed:
agent_install_dir\.config
- Open the following file in an editor:
OasisConfig.properties
- Modify the following port assignment:
oasis.jxta.port=
- Save the file. Close the file.
- Navigate to the following directory on the server where the Domain Orchestrator is installed.
install_dir/server/c2o/.system
- Remove the .c2o folder, if it exists.
- UNIX or Linux: Adjust the boot configuration.
