Add a Node to the Domain Orchestrator › Synchronize Time for a Cluster Node
All cluster nodes for any Orchestrator must have the exact same clock time, which is synchronized with a standard external time server. Take one the following approaches to synchronize the time of all nodes in a cluster:
- Synchronize all Orchestrators and cluster nodes to a standard external time server (preferred).
- Manually synchronize the time of all additional cluster nodes as follows:
- Verify the accuracy of the time of all cluster nodes.
- Run the appropriate OS command on each cluster nodes to synchronize the time of all cluster nodes.
