Each Orchestrator requires three logical data stores:
Note: Multiple Orchestrators can share the Repository data store on the Domain Orchestrator or each Orchestrator can have its own.
Note: Each standalone Orchestrator requires a separate Runtime data store. Because an Orchestrator cluster is seen as a single logical Orchestrator, all nodes share the same Runtime data store.
Note: The Reporting data store is typically shared among all Orchestrators.
The CA Process Automation data stores can share a physical database, but the best practice is to have a separate database for each data store. CA Process Automation requires database names to be case insensitive.
We recommend a minimum of 40 GB for your databases. Specific operations such as upgrading CA Process Automation make unusually large demands. Having ample space and periodically monitoring space consumption is a good practice.
Archiving policy considerations
Note: When the policy is set to take no action, we recommend that you perform data archiving tasks outside of CA Process Automation.
Note: See "Configure Orchestrator Policies" in the Content Administrator Guide.
