Part of planning a CA Process Automation system is determining what new components you can colocate on the same host with the CA Process Automation Domain Orchestrator and which ones to install on separate hosts. Let us consider these components of a CA Process Automation network.
Each cluster node and each Orchestrator is typically installed on a separate host. The NTP server can be external to the network.
For a lightly loaded CA Process Automation, you could install the following entities on the same host on which you installed the Domain Orchestrator:
Consider the following factors when determining whether to colocate entities or use multiple hosts:
Major factors include the quantity and speed of CPUs, memory, disk storage and networks.
Consider not only the total number of processes, but also their max sustained rates during periods of peak activity.
Not all processes are equal. Some processes have few operators, others have hundreds. Some processes contain many CPU intensive activities, while others spend most of their time waiting for events or user interactions. This variability makes it difficult to specify loading in terms of process volume/rate. Even at the finer granularity of operators, throughput varies.
Real-time responsiveness is never attainable with the current implementation. However, even less stringent requirements factor into when more hardware for additional Orchestrators come into play. With a stringent SLA, the system needs more spare capacity so that the peak periods still perform well. Without an SLA, the system needs only sufficient capacity to cover the average load.
Consider what else the CA EEM and the RDBMS are used for.
In anticipation of future growth, we recommend against colocating CA EEM and the database with the Domain Orchestrator. The only sure way to determine when you have enough resources is by actual full load testing.
