The CA Process Automation installation media includes the following sample configuration file for the Apache load balancer that you can use as a starting point for configuration:
ApacheConfig.zip
The following instructions assume that an Apache 2.2 load balancer is dedicated to CA Process Automation. First, install an Apache load balancer. Then, extract files from the CA Process Automation ApacheConfTemplates zip file to the Conf folder under the Apache installation folder.
The load balancer typically is not on the same host as your Domain Orchestrator. However, the host with your Domain Orchestrator must be routable from the load balancer.
mod_jk.so
We recommend that you download the latest version.
apache_install_dir\modules
install_dir\DVD1\ApacheConfTemplates
mod-jk.conf
httpd-proxy.conf
uriworkermap.properties
workers.properties
httpd VIRTUALHOST_EXAMPLE FILE
Note: The extracted httpd VIRTUALHOST_EXAMPLE FILE file contains text you can cut and paste into the Apache httpd file when you configure secure communications. The required text is also in the documentation.
mod-jk.conf
httpd-proxy.conf
workers.properties
Note: If you do not have an Apache 2.2 load balancer to dedicate, merge the configuration information in the example template properties and Conf files into your existing files. As a precaution, back up your files before you modify them.
