Install Agents › Prerequisites to Installing Agents › Verify Java Prerequisites for Agents
Before installing an agent on a host, verify that Java prerequisites are met.
- Log on to the host. Make certain that a supported version of a Java Runtime Environment JRE is installed. If no suitable version is present, download the JRE from the vendor and install.
- (Optional) Set JAVA_HOME environment variable to the path of the JRE for the agent. If this variable is not set, the CA Process Automation installer prompts you to browse to the directory where JRE is installed.
