Symptom:
If an initial attempt to install CA Process Automation fails, subsequent attempts to install CA Process Automation at the same location also fail.
Solution:
To reinstall CA Process Automation, either clean up the leftover registry entries, files and folders at that location before you begin the installation, or use a different location.
