Use CA SiteMinder with CA Process Automation › CA SiteMinder Prerequisites
Verify that your system meets the following prerequisites to install CA Process Automation with CA SiteMinder:
- A CA EEM server that is integrated with the same LDAP/AD that is used as a User Directory in the SiteMinder Policy Server.
- A CA SiteMinder Secure Proxy Server (CA SiteMinder SPS) installed and configured with Policy Server.
For security, work directly with your CA SiteMinder Administrator to understand and follow all existing guidelines for your organization's use of CA SiteMinder.
Important! You must reinstall CA Process Automation Agents (instead of merely restarting) when the Domain Orchestrator URL changes. The following changes can affect the Domain Orchestrator URL:
- Changing the Domain Orchestrator from SSO-enabled to SSO-disabled.
- Changing the Domain Orchestrator from SSO-disabled to SSO-enabled.
- Pointing the Domain Orchestrator to a different SSO server.
