Link properties display when you right-click a link in a process, then select Link Properties.
Specifies the thickness of lines between operators.
Opens the Choose Link Color dialog, in which you can change the color of links in the process.
Specifies the line shape for links between operators:
Creates straight links between operators.
Creates right-angled links between operators.
Click this check box to create a dashed (dotted) link.
