The Dynamic Parameters provide update values in a SOAP request.
Specifies the method with which to update values in a SOAP request. The Web Services operators support the following methods at run time:
Specifies that XPath expressions in the Parameters List parameter update values in a SOAP request.
Specifies that macros in the Parameters List parameter update values in a SOAP request.
Specifies the unique data entries in the SOAP request.
A best practice is to add the parameters in the same order in which the WSDL specifies them for the SOAP call.
Each parameter contains the following values:
Defines the name of the macro or the XPath query. If the value is the name of a macro, the value substitutes the macro name. If the value is an XPath query, the value updates the node that the query returns.
Specifies a runtime value for the parameter.
Specifies one of the following data types for the parameter:
