Defines the IP address or fully qualified domain name for the agent host. For example: 192.#68.1.254
To specify a port with the host name, use either of the following formats:
For example: comet.hq.company.com:10162
Defines the community under which to access the variable (for example, public).
Defines the object ID (OID) for the variable. The management information base (MIB) associated with a remote agent documents the OIDs. For example: 1.3.6.1.2.1.1.1.0
Defines how many times the product retries a failed request.
Defines the interval in seconds the product waits for a Get SNMP variable before the operator times out.
Specifies a data type for the variable. To configure this parameter, select a value from the drop-down list.
Defines the maximum interval in seconds between attempts to check the value of the watched variable.
Specifies the SNMP agent version number. Select Version 1 or Version 2 from the list.
Defines the minimum expected numerical value.
Defines the maximum expected numerical value.
Defines the pattern for which the operator searches (for more information, see the Content Designer Guide).
Separators (#) in the pattern delimit the text to save to operator dataset variables.
Defines the character that delimits the zone to save to the variables that variable names specify.
Defines the variable names in which to save text that matches the delimited zones in the pattern. The product saves delimited zones to the listed variables in order. The product uses the keyword process to access operator dataset variables through the process dataset.
For example, specifying the variable names V1 and V2 assigns extracted substring values to the operator dataset variables Process.Operator_name.V1 and Process.Operator_name.V2. To add, remove, and order the variables to store the matched strings, use the toolbar.
Specifies whether to use case-sensitive pattern matching.
Selected: Match upper-case and lower-case letters in a pattern only with letters of the same case.
Cleared: Ignore case when matching the pattern.
